Matlab 'keyboard' from Labview?
hi,
i'm using win2k, Labview-7 & Matlab(13).
Within the LV formula script, is it possible to use 'keyboard' command in Matlab script?
i use input and output to the script to let the Matlab finish execution before Labview continues... however, Matlab window doesn't display & Labveiw locks up.
i sure would like interactive Matlab from Labview scripts.
thanks for your input.
(2,760 Views)
> in Matlab script?
Apparently not. I don't have access to Matlab, but the script node
works by passing the information to matlab using the ActiveX automation
interface. You might look for documentation within Matlab indicating
which commands do and don't make sense for automation.
Greg McKaskle
(2,760 Views)
