Matlab fuzzy logic in Labview
I'm working with the fuzzy logic toolbox from matlab. I created a .fis file with some rules from the fuzzy editor in the fuzzy logic toolbox from matlab, wich I want to run in labview, with the matlab script. How can load the fis file? I tried with the examples attached, but it didn't work.
(4,494 Views)
I have also noticed you have posted on another thread with the same issue I have added a link just to tie them together
http://forums.ni.com/ni/board/message?board.id=170&message.id=180182&jump=true
(4,463 Views)
Hi Tim,
actually I have posted two different threads. This thread is concerned about using Matlab node inside Labview program. The other thread is concerned with the values produced by Labview and Matlab fuzzy logic toolbox/toolkit.
I did not get any error message when I ran the program fuzzy_test.vi. I just did not get any result at all.
Perhaps Labview Matlab node is not designed to call Matlab fuzzy logic command like readfis, evafis, etc? Any idea?
Dedy
(4,454 Views)
