Matlab R13 vs Labview v 7.1
Hello guys
I have some problems solved previously with MATLAB need to be solved
with labview using the new Control Design Toolbox.
A really simple problem appeared while using the Transfer function to
State space model conversion VI because the results appear totally
different from those in matlab.
The main problem is when u use SS to TF VI and feed it back to TF to
SS VI u don't get the same result.
I examined the SS to TF VI and i think the problem is cause with a
stability matrix T where it is multiplied to the matrices A,B,C and D
which are correctly computed in the first step of the VI.
If any body have any information on this topic. Please respond.
Thank you
(2,950 Views)
There is no set procedure for how these transformations should occur. Each systems response should be the same despite the different transformations used in converting from a transfer-function to a state-space model.
It appears that Matlab will return the state space system in controller companion form. You can use the "CD Canonical State-Space Realization VI" to convert from the form returned from the "CD Convert to State-Space Model VI" to the controller companion form you are observing in Matlab. You just have to specify �Controller Companion� as the form type.
I will attach my VI and M file for comparison.
(2,950 Views)
