Mathscript natural log issue
Hello, I am brand new to LabView and programming itself, so sorry if this question is as stupid as I'm assuming it will be. I am trying to write a VI that uses mathscript to output the percent deviation of Stirling's approximation from the actual value of ln(N!) using a factorial sub VI that I have created. I keep getting an error in the mathscript formula with ln, and I have no clue why. If anyone could help me out with this, that would be much appreciated.
(5,207 Views)
What it the error?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,172 Views)
I think you need log(x) for the natural logarithm. (See also this table, ln(x) is not a recognized function)
(we are also missing your subVI. I am not sure why you even use mathscript for this. Plain LabVIEW primitives would be sufficient.)
(5,157 Views)
Here's a quick draft showing the output of N! (stock LabVIEW) and the Stirling approximation. No Mathscript needed. I am sure you can easily add the percentage deviation calculation.
(5,142 Views)
