MathScript - Array size into function issue.
Sorry if this is considered the wrong forum but the mathscript forum seems dead.  I am trying to utilize the fir_fs function to create some fir coefficients.  Both matlab and octave don't seem to have an issue with large arrays for the fir2 function which fir_fs is based on but Mathscript seems to choke on anything more than a couple hundred points.  See attached example.
(2,951 Views)
Hi nkeddem,
Thanks for attaching the fir_fs test VI. This behavior is a known issue which is filed under the Corrective Action Report #360900 and is currently being investigated by our R&D team. I understand that you worked with an Applications Engineer to get a work-around to address the behavior. Let us know if there are other concerns regarding the fir_fs Mathscript function.
Aldo A
(2,902 Views)
