Math with arrays
I haven't had much experience working with arrays in labview and I'm looking for a way to do more complicated math than the "add/multiply array elements."
More specifically, I have a 2-D, 4 row, 3 column matrix ( lets call them x, y, and z, with elements x1, x2, x3, and x4, and the same for y and z.
I need to compute the average for the elements in the 1st and 3rd columns: (x1+z1)/2 = xz1 avg
And then I need to use that result: (xz1 avg - y1)/xz1 avg
For each row in the array.
Do I need to split the array into 3, one for each column, to do this?  Or is there a formula node that lets me specify which array column/row/element to use?
(6,169 Views)
All you need to use is Index Array.
(6,158 Views)
Hi
You can use Index Array to choose one element from an array, try using context help Help>Show Context Help to see how to wire the Index Array. For further help you can also use Help>Find Example where you can find usefull examples. Index Array can be also expanded. I have posted a picture of connecting the index array.
Hope it will help.
(6,154 Views)
By default, autoindexing FOR loops iterate over Rows, so once you have the math for one row, simply place it inside a FOR loop and iterate over all rows.
Here's an example:
(6,146 Views)
