Math help: calibrating adxl375
I have to 12 point calibration of adxl375. I have attached a datasheet of the method. Page 7 shows the equation 1 which i have to solve.
It has 12 known.
We keep sensor in six different poisition, each generate 3 set of equations to fit in the matrix. Equations arre below. I have filled value of Ax,Ay,Az:
How to solve that in labview??
/* +z axis */
a11*30 + a12*50 + a13*2548 + o1 = 0
a21*30 + a22*50 + a23*2548 + o2 = 0
a31*30 + a32*50 + a33*2548 + o3 = 1
/* -z axis */
a11*20 + a12*10 + a13*980+ o1 = 0
a21*20 + a22*10 + a23*980 + o2 = 0
a31*20 + a32*10 + a33*980 + o3 = -1
/* +y axis */
a11*30 + a12*1911 + a13*50 + o1 = 0
a21*30 + a22*1911 + a23*50 + o2 = 1
a31*30 + a32*1911 + a33*50 + o3 = 0
/* -y axis */
a11*20 + a12*49 + a13*10+ o1 = 0
a21*20 + a22*49 + a23*10 + o2 = -1
a31*20 + a32*49 + a33*10 + o3 = 0
/* +x axis */
a11*2303 + a12*30 + a13*50 + o1 = 1
a21*2303 + a22*30 + a23*50 + o2 = 0
a31*2303 + a32*30 + a33*50 + o3 = 0
/* -x axis */
a11*392 + a12*20 + a13*10+ o1 = -1
a21*392 + a22*20 + a23*10 + o2 = 0
a31*392 + a32*20 + a33*10 + o3 = 0
(3,779 Views)
Hi Vindhy,
to solve this:
you might use the basic "Solve Linear Equations" function:
Adding the ACC_x0 vector should be easy as last step…
(3,741 Views)
1. I have made a equation as in attached excel file. Equation has 18 varaibles.
2. Then I took 6 readings from adxl375 which in turn form 18 equations.
Equations are in matrix form in block diagram of labview program attached.
3. I am getting error: 20001;  The matrix is rank deficient
4. I don't know why this error. i have 18 equations & 18 variables.
5. With error, I still get values in "Solution matrix" in front panel. These values when i put back in equation , I got result as in "AxB" in front panel.
These values are almost matching result. So not a problem at this stage.
I want to know is there any more aggressive method to get exact results.
(3,700 Views)
Edit: Excel file contain the matrix formed
(3,698 Views)
I have been able to do 12 & 15 point calibration both.
I have also attached example for anyone reference.
Solution matrix contain the unknown found.
AxB matrix contain values found in solution matrix to equations.
results are good.
Query:
Find data AxB is very accurate according to my need.
But still values are off a bit.
Is there any more aggressive method to find exact solution?
(3,660 Views)
