Math Script
I want program the below equation using math scrip , i am using labview 8.5
Cal =  -10 + (1.3 * ln (x + 0.3)) + (1.2 * ((ln (x + 3.7)) ^ 2)) +(0.03 * ((ln (x + 3.7)) ^ 3)) + (0.05 * ((ln (x + 2.7)) ^ 4))
Where X is control input from user.
Message 1 of 12
(7,106 Views)
OK.... so what's your issue? Do you not know how to use MathScript? Are you unsure about the syntax? Are you asking how to set X as a variable? Have you looked at the LabVIEW Help? Have you looked at the examples?
Message 2 of 12
(7,094 Views)
Like this?
19507iFB139DE146531983
Andy Chang
Message 3 of 12
(7,091 Views)
Hi andy,
              I did the same as told by you, i am getting a error "semicolon missing " . i am trying out formula node for the first time
Message 4 of 12
(7,061 Views)
The formula node is a different beast. For MathScript you need to use the MathScript node, located in the Mathematics -> Scripts & Formulas. The MathScript node has a blue border. The formula node has a dark gray border.
Message 5 of 12
(7,057 Views)
Hi ,
          Tried to search for Mathscript under Functions>>Mathematics>> Scripts & Formulas palette but couldnt find only only i can see Xmath Script and Matlab Script . Is there any additional toolkit required ???
Message 6 of 12
(7,042 Views)
Is LabVIEW correctly activated on the computer? Do you have the edition that actually has MathScript? Check by launching the NI License Manager (on Windows it's Start -> All Programs -> National Instruments -> NI License Manager). Then check to see which development version is activated.
Message 7 of 12
(7,031 Views)
Aside: Is there a reason you're not doing this with LabVIEW functions directly?
Message 8 of 12
(7,023 Views)
just wanted to give a try how it works
Message 9 of 12
(6,996 Views)
OK, that's fine. I was just curious.
Did you check your activation?
Message 10 of 12
(6,988 Views)
