Math Interface Toolkit creation error
hi,
i'm using labview 7.1 with windows 2000. i installed math interface toolkit 1.0. but when i try to create a mex file from a vi i get the following error
"At least one of the MEX-file creations was not successful. To call any of the successfully created MEX-files, The MathWorks, Inc. MATLAB(R), the Math Interface Toolkit Run-Time, and version 7.1 of the LabVIEW Run-Time Engine must be installed."
i tried different vi's but no luck. any ideas?
thanks.
(3,658 Views)
Hi Omr,
A few quick questions:
1) Is there an error number associated with that error?
2) What versions of each of the pieces of software listed do you have installed?
3) Can you create a super simple VI and MEX file to simply add 2 numbers?
Chris J
(3,654 Views)
hi chris,
thanks for your reply.
1) no error number is associated with that error message. when i click on the more info button displayed with the error message. NO ERROR is displayed in the Failure Description
2) LabVIEW 7.1.1 and Math Interface ToolKit 1.0. I upgraded from LabVIEW 7.1 to 7.1.1 and mass compiled. that didnot solve the problem.
3) tryed it same problem.
thanks.
omr
(3,642 Views)
my LaView  is the base development system.
(3,627 Views)
Hello Omr,
I created a simple test.vi and built its corresponding mex-file. The VI and completion message are below. If you cannot build a MEX file with this VI, you may want to try reinstalling the toolkit. Good luck!
Chris J
"The MEX-files were created successfully. To call any of the successfully created MEX-files, The MathWorks, Inc. MATLAB(R), the Math Interface Toolkit Run-Time, and version 7.1.1 of the LabVIEW Run-Time Engine must be installed."
Message Edited by ChrisJ on 12-27-2005 05:21 PM
(3,612 Views)
thanks chris.
(3,604 Views)
