Matching pursuit
Is there an algoritm for Lab View 7 called Matching Pursuit (MP), ment for detecting spindles from EEG signal?
I read a signal from a file and I need to detect segments that are in certain frequencies.
Message Edited by Priit323 on 02-27-2006 08:23 AM
(2,737 Views)
I am not very familiar with EEGs, but if you are looking for a peak detector of sorts, there is a Peak Detector VI in the LabVIEW Full development system and higher. Just go to the controls palette and select the magnifying glass in the upper right and search for peak. I hope this helps,
Cheers,
Chris J
(2,704 Views)
