Match pattern
Can anyone tell me how to set up a match pattern so that it does not
confuse these two strings:
prompt>
If the regular expression is ">", it will find it in the "prompt>"
string. I do not wish for this to occur. I wish for the match pattern
to detect the ">" case separately from the "prompt>" case. Since I do
not know which one will be present in the string, I have to account for
both conditions.
Thanks in advance.
Scott
(4,227 Views)
Hi Scott
Just playing around with a few Match patterns. If you try the regular
expression: ".+[>]" (without the quotes) with the Match Pattern function,
a match is only found when there is 1 or more characters preceding the
">", or else the Match Pattern function returns "-1" at the "offset past
match" output terminal. Is this what you wanted?
Paul
Research Assistant
School of Physiotherapy, Curtin University of Technology
Selby Street, Shenton Park, Western Australia, Australia. 6008
email: P.C.Davey@curtin.edu.au
Tel. +61 8 9266 4657 Fax. +61 8 9266 3699
"Everyone who calls on the name of the Lord will be saved." Romans 10:12
"For all have sinned and fall short of the glory of God, and are justified
freely by his grace through the redemption that came
by Christ Jesus."
Romans 3:23-4
> prompt>
> both conditions.
> Thanks in advance.
> Scott
(4,227 Views)
does anything appear in the string immediately before the ">", such as a
"newline", tab or space?
if so, you could match pattern to " >" or whatever, in which case "t>" would
not qualify.
Scott Serlin wrote in message <397DCF41.4DA1C2E1@comm.mot.com>...
>prompt>
>both conditions.
>Thanks in advance.
>Scott
(4,227 Views)
On Tue, 25 Jul 2000 12:32:49 -0500, Scott Serlin
>prompt>
Look up in the online help (i mean the real online help not the small
help window 🙂 or the manual and you will find a more information
about (LabVIEW's) regular expressions.
By the way, your match string should be "^>" to match > at start of
string or "^>$" to match a string with only >
(Match string should be without the quotes)
Rolf
(4,227 Views)
Scott,
I'm a novice to LabView, but this is what I would try. Search for the '>'
character, if the result is position 0, then you have the right one. A
greater returned value means it has a prefix of some sort. You could also
try checking the length of the prompt while you are checking the content.
I hope this makes sense, I'm normally a VeeTest user, just getting into
LabView.
Tom H.
>prompt>
e. Since I do
>both conditions.
>Thanks in advance.
>Scott
Certified LabVIEW Developer
(4,227 Views)
