Match all characters excluding ones "inside the double quote"
I have a string with the structure like this "any characters" + !$abCD + "any characters".
I woud like to match the string  !$abCD (This string must include !$)
I intend to use the Match Regular Expression.
Thank you in advance.
Message 1 of 18
(9,779 Views)
\!\$abCD will work.
I usually use https://regex101.com to test regexes. It gives direct and clear feedback.
Certified LabVIEW Architect
Message 2 of 18
(9,746 Views)
plusses part of the string? Or does the next part begin with the quote?
To build on @Thols post
\!\$[^"]* - matches all up until "
\!\$[^+]* - matches all up until +
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 18
(9,743 Views)
Or maybe you wanted to catch !$abCD only within the pluses? Then this will output it in  a submatch:
\+ (\!\$abCD) \+
Message 4 of 18
(9,736 Views)
Or if you want to catch everything within the pluses:
Message 5 of 18
(9,735 Views)
/Y
The expected matching sometimes is #something, $something, %something or !#something, !$something, !%something.
How will the expression be?
Message 6 of 18
(9,729 Views)
Why do you use this expression [^\)] to catch everything?
and I would like to have the general expression to catch the strings excluding ones inside the quote.
The format of the desired strings has the prefixes such as !#,!$,!%, #,$,% (i.e, !#ABCD)
The input string can have one or more "+"
Message 7 of 18
(9,727 Views)
'roof' is 'not' so [^)] matches everything _except_ end parenthesis. Then, as it's an end parenthesis after that, it'll match everything within a parenthesis and include the end parenthesis. If you only search for ')' it's usually greedy and'll grab the last one in the string. (There's an option that can make it 'lazy' and grab the first one).
/Y
Qestit Systems
Message 8 of 18
(9,701 Views)
The lazy operator is .*? so in this case you should be able to use:
Qestit Systems
Message 9 of 18
(9,699 Views)
This page (Rexegg: Mastering Quantifiers) might be useful when reading about lazy and greedy matching.
Remember that LabVIEW uses the PCRE library for regular expressions (at least when it is considering real regular expressions - sometimes LabVIEW has nodes that have regular-ish expressions with limited syntax but often faster execution: see the help for Match Pattern for an example)
GCentral
Message 10 of 18
(9,683 Views)
