Match Pattern with shortest string pattern instead of longest string .*
A sometimes overlooked feature of Match Regular Expression is that you can resize and index the capture groups.
Use .*? for a lazy match...
Message 11 of 18
(7,236 Views)
As posted by PhillipBrooks,
you can use Match Regular Expression with the following pattern: .*? to use non-greedy matching (also you can use .+? and {2,5}? ).
Online help: http://zone.ni.com/reference/en-XX/help/371361L-01/lvhowto/regular_expression_patterns/
Message 12 of 18
(7,224 Views)
Philip, if you don't put ab in a capture group you only need to expand the output for (.*?).
To remove the empty spaces before cd and after ef the following regex can be used: ab\s*(.*?)\s*ab (or use TrimWhitespace.vi at the output).
If you want to capture all sequences between ab pairs you need to use a lookahead (the second ab pair will not be part of the match), If we have the following sequence: uv tk ab cd ef ab gh jk ab lm op ab
Your regex will match cd ef and lm op ignoring gh jk
Using the following regex ab(.*?)(?=ab) you will match all sub-sequences between ab pairs
Ben64
Ben64
Message 13 of 18
(7,165 Views)
Suddenly the code is about as complex as my version using "scan strings for tokens" above... 😄
Message 14 of 18
(7,148 Views)
With a known delimiter I would probably lean Spreadsheet string to array.  That said:
Message 15 of 18
(7,125 Views)
@Darin.K wrote:
That said:
I knew that Dr. Regex would come up with a very long line of gibberish that does exaclty what the OP wanted. 😄
Message 16 of 18
(7,105 Views)
Someday, if i should happen to have a massive aneurysm at my desk, and so, exit this world for the next, I can guarantee that there will be unfinished regex code on a block diagram on my monitor.
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
Message 17 of 18
(6,998 Views)
All regular expressions by definition are unfinished and subject to improvement or simplification.
Message 18 of 18
(6,938 Views)
