Match Pattern labview
I am new in labview, and I am trying to search some Process id from a string:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
c:\> tasklist /fi "imagename eq notepad.exe"
Image Name                   PID Session Name     Session#    Mem Usage
notepad.exe                 2964 Console                 0        728 K
notepad.exe                 2432 Console                 0      1,044 K
what I want to get is these PID: 2964 and 2432. I have tried to use multiply string functions, but I think this one can make it.
Can someone help me set up the regular expression? Thanks in advance.
Message 1 of 11
(5,784 Views)
George,
The forum is not normaly devoted o doing a student's homework.
We like to share thoughts with fellow NI enthusiasts! Even those that are new to NI or (on this forum) LabVIEW.  Reply with own question, your Prof's URL, or do your own homework!
"Should be" isn't "Is" -Jay
Message 2 of 11
(5,776 Views)
Hello George_Z
       Have you tried using array functions where you need to give the no.of column and can vary no. of rows to get what you want. Hope it helps...
I
Message 3 of 11
(5,760 Views)
Hi George,
Read your text from the line that looks like the header for the information contained below [Image Name                   PID Session Name     Session#    Mem Usage].
Put this data into a 2D Str Arr. Index the 1st column alone as a 1D Str Arr. Then take the word PID from its 0th element. In the same array look for the word ' Console' ['\sConsole] using the Match pattern function & take out the portion of the Str found before the match.
Look carefully that I have included a Space ('\s') character along with the pattern to be looked for and matched.
- Partha ( CLD until Oct 2027 🙂 )
Message 4 of 11
(5,757 Views)
This assumes that you'll always have " Console" before the PID.
I have a suspicion that there's a better Regexp, but I can't do it.
Jim
Message 5 of 11
(5,744 Views)
Here is a cool solution to your problem. Should work with Labview 8+
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 6 of 11
(5,727 Views)
Jim
Message 7 of 11
(5,708 Views)
Did it not work?
Message 8 of 11
(5,706 Views)
Coq rouge wrote:
Did it not work?
Well, it doesn't do what the poster originally asked for, and it also does not place a tab between the process ID and the Session Name. Other than that, it works just fine. Smiley Wink
Message 9 of 11
(5,687 Views)
Well my solution is some kind of a more general type I shall admit ;). Also if George_Z  wants the pid he can just index the correct cell and convert the PID+Session name to a number. I did that on purpose. I could not solve his entirely assignmentSmiley Very Happy
Message 10 of 11
(5,681 Views)
