Master-slave 2-wire communication with Temperature Controller via Modbus RTU (USB-485) protocol.
I am also using the USB-485/1 adapter from NI.  It has a DB9 (male) connector which I plugged to a DB9 (female) externally do the wiring related to the 2-wire communications (pin4-8 and pin5-9).  I didn't connected pin 1 (GND) to anywhere else though.
I tryed what Closing the VISA port as you recommended (just like in the example), but continue having the same old error from previous posts....damn!
Message 11 of 12
(1,045 Views)
Hi guys, it works now! :smileyvery-happy:
Here's what I made
HW Related:
I re-made the cable which communicates the USB-485 with my TC's.
SW Related:
I pulled out another PIN out of "MB Serial Init.vi" to manually control the "Stop Bit" variable
I set the same timout time in my TC's and in LV.  In the "MB Serial Init.vi" there's a default time of 100000ms, but the max. timeout in my TC's was set to 250ms
Now I am using the following parameters:  RTU, 8,n,2, timeout=250, flow control=none
Thanx again for all your comments, I  hope these posts are useful to someone....i think it was the cable all the time:S
Message 12 of 12
(1,026 Views)
