Mass Compile compactRIO RT project
I am trying to mass-compile a project in Labview 2011 for a compactRIO target. During the compilation, I get a series of badVI messages for all VIs which include the FPGA reference.
In my code, I open the FPGA-VI reference in the realtime top-level-VI and pass it to several subVIs via bound typedefs as explained here:
Why Do I Have a Broken Wire When Passing My FPGA VI Reference Into a SubVI?
This works great in the project, none of the subVIs have broken run buttons when opened there. Just the mass compile does not work.
My question:
Is it normal that mass compilation doesn't recognize the FPGA reference type-def or is this an indicator for a problem like corrupted VIs?
Why I am doing this: We are migrating the project from LV2010 to LV2011 and are experiencing crashes of the IDE in the new version. A mass-compile seems like the most straightforward way to make sure that our code is healthy.
Labview 2011(32bit) on Win7(64bit)
cRIO 9012 + cRIO9111 backplane and some c-Series cards
Thanks in advance, any help would be greatly appreciated.
(2,780 Views)
bump....
(2,751 Views)
Hi cermf,
sorry for the delay. In my opinion, the easiest way would be to delete all the FPGA-reference ins and outs of the subvis, masscompile, and replace them
with the input control and output indicator you create once in a LV 2011 Project from a LV FPGA Reference VI which is set to "dynamic".
It is a bit of work (depending on the project size), but it will prevent you from trouble in future versions from this point on.
kind regards
Marco Brauner NIG
(2,743 Views)
Hi Hans Aplast,
thank you very much, I did what you said and it removes the BadVI messages, for all real-time VIs except the toplevel one where the FPGA-ref is created.
After that I tried a few other things like making the FPGA-reference non-dynamic or trying a different FPGA-VI, but the only way to remove this last BadVI was to remove the FPGA-reference altogether from the toplevel VI. Which is pointless since I need the FPGA.
Even substituting the real-time toplevel VI with this dummy and the FPGA-VI with a similar dummy doesn't remove the BadVI-message.
real-time toplevel Dummy
Anything else I could try to resolve this?
kind regards
Christian Freier
(2,733 Views)
