Maps and Config Files
I started using maps (finally).  Needing to initialize them from .ini files, I made this.
Message 1 of 20
(3,917 Views)
Malleable VI would have made your life easier I believe, not sure if there is a limitation of VIM with Maps.
Santhosh
Soliton Technologies
Message 2 of 20
(3,897 Views)
This does seem to generally work for the writes at least. INI tokens are fairly limited in terms of acceptable data types so you might have to be careful. It doesn't accept all data types (variants and clusters break) but it will take a U64 map and write a double to INI which could cause runtime issues. Of course you could fix this with type checking but I'm not sure how much effort that would save over the existing poly VIs.
Message 3 of 20
(3,884 Views)
I haven't looked at you code, but have you considered moving away from INI format for config files?  INI is great for simple things, but poor for complex config info.
Message 4 of 20
(3,861 Views)
I considered that, but most of the time I’ll be using the “read” functions, and most of the time, I won’t need to wire the map nor default inputs.  So I made it polymorphic in order to have a selector.
Message 5 of 20
(3,853 Views)
I actually have a nice OOP based config file system that handles any data type.  But sometimes it’s desirable to have human-editable files.
Message 6 of 20
(3,849 Views)
I mean something like JSON.  Still human editable, but capable of storing complex data.
Message 7 of 20
(3,834 Views)
I consider that a bad compromise.  Readability is unpleasant.  Try explaining to a non-tech how to change a setting in a JSON file.  And from a programming standpoint, the code wouldn’t be as clean as using a binary file.
Message 8 of 20
(3,789 Views)
Seems very readable to me.  An example:
  "Module_DB file":"",
  "SQLite busy timeout (ms)":10000,
  "Analysis Configuration":[],
  "Column Widths":{
    "AnalysisName":82,
    "Camera":65,
    "Colour":46,
    "ImageIndex":21,
    "InValid":42,
    "Pattern":52,
    "TestTime":131,
    "unitID":111
  "Overlay Options":{
    "ID":true,
    "Alignment":{
      "Alignment Markers":"Input and Output",
      "Edge Detection":false,
      "Circular IG":false
There is no way an OOP-based config system is going to be as clean to code as using a good JSON library.
Message 9 of 20
(3,779 Views)
  "Column Widths":{
    "AnalysisName":82,
    "Camera":65,
    "Colour":46,
    "ImageIndex":21,
    "InValid":42,
    "Pattern":52,
    "TestTime":131,
    "unitID":111
  "Overlay Options":{
    "ID":true,
    "Alignment":{
      "Circular IG":false
Better readability than XML for sure, more intimidating than a classic config (.ini) file for a non-tech person, though.
Bill
CLD
(Mid-Level minion.)
Message 10 of 20
(3,738 Views)
