Mapping to Variables Using SIT Connection Manager
I have a quick question regarding the SIT Connection manager and mappings.  I was wondering if it is possible to map to variables, using the SIT Connection Manager Wizard, that I can make in the Project Window and drop into my block diagram.  I have the SIT system buried under another VI and it is a hassle to keep having to connect the variables up to their values.  I would like to just be able to map directly to them.  If this is or is not a possibility please let me know.  Thank you.
Michael B
LabVIEW 8.5
SIT 4.0
Message Edited by Michael B on 11-30-2007 12:52 PM
(2,916 Views)
Hey Michael,
Thank you for contacting National Instruments.  I am not sure if I completely understand your question.  Would it be possible for you to walk me through the process you are currently going through to set up these mappings?
Also, I wanted to clarify what you meant by connecting to variables.  I know you can use the manager to map to indicators and controls, but I am not sure if this is what you are trying to accomplish.
I look forward to hearing back from you.
Kevin H
WSN/Wireless DAQ Product Support Engineer
(2,895 Views)
     Thank you for the response.   I have recently found my answer and forgot to close the discussion on this forum.  The question that I was asking was whether or not I was able to use the SIT connection manager for the Variables, that I make in the project window, to link them to indicators and controls.  Now I know how to use variables from a demonstration and reading examples.  Thank you for the reponse and sorry I did not close this thread before.
Michael B
(2,883 Views)
