Map bug: IPE + for loop compiler error (LV2020)
Hi all,
There appears to be a compiler bug when an IPE accessing a map is placed inside a for loop. Steps to reproduce the bug:
  1. Create a map constant.
  2. Create an IPE for map access, and wire the constant to the IPE border node.
  3. Wire any required inputs so the run arrow isn't broken.
  4. Create a for loop around the IPE structure, but not around the map constant. This will cause the map to auto index. The wire to the IPE becomes a cluster, but doesn't break.
  5. Run the VI. A compiler error appears: "copy cvt, csrc=0x50"
The snippet below can be dragged on to the BD and will also throw the compiler error.
Is this a known issue?
Message 1 of 8
(3,076 Views)
Accepted by topic author Dataflow_G
Thanks for reporting this behavior. I have reproduced the problem with your instructions, and opened Bug #1106870 for our team to review.
All the best,
Message 2 of 8
(2,993 Views)
@Dataflow_G wrote:
Hi all,
When you have a "MAP" input node into the for loop, the map is converted to a cluster array; that is, it is no longer a map. Reverse some of steps, for loop first, then IPE, get a broken wire. You need a shift register on the side of the for loop to access the map.
mcduff
Message 3 of 8
(2,983 Views)
mcduff
I know I did things a little backwards, and was expecting the auto-index cluster behavior and broken wire after adding the for loop. So it was interesting the wire didn't actually break, and after running the VI to see what would happen produced the compiler error.
Message 4 of 8
(2,962 Views)
So the bug here is the IPE map node even accepting a non-map datatype?
Just curious. Never used maps, but like to keep up to date.
Message 5 of 8
(2,938 Views)
I agree with your assessment. I would classify it as an editor/IDE type bug. You should have a broken wire but the editor/compiler does not catch it. If you reverse some of the steps, the editor catches it.
mcduff
Message 6 of 8
(2,922 Views)
Huh... If you wire the cluster directly, the IPE allows it...
Then create an output indicator...
Then Undo the Create Indicator (I used Ctrl+Z)...
And *then* it breaks. (Just selecting/deleting the indicator does not break the wire.)
Spoiler
It's probably all the same bug, but it's interesting to tinker and see what happens.
I agree, too: It seems to be something that the Editor should not allow. (Not that my agreement adds much at this point. 😄)
-joeorbob
Message 7 of 8
(2,903 Views)
Better late than never?
Bill
CLD
(Mid-Level minion.)
Message 8 of 8
(2,895 Views)
