Manually Controlling 3-Way Valves with Labview
That doesn't take an analog voltage.
It is a solenoid.  It needs a voltage, but it is either on or off.  You need to use a digital output from a cRIO.  Since it probably wouldn't have the voltage or current capacity, you may need the digital output to drive a relay which would drive this solenoid.
Message 11 of 11
(688 Views)
