Manipulating array
Sorry for the non accurate title, but it was difficult to really explain it better.
I would like to realise this in a for loop :
I'm so lost when I have to manipulate these arrays !
Thanks you for help,
Sébastien
Message 1 of 17
(6,332 Views)
Accepted by topic author Zepiii
This is an interesting problem.  See if this does the job for you.
Message 2 of 17
(6,296 Views)
Ooow, sorry, I forgot to precise that "Xa1,..." are in fact a number, I just wanted to give the representation of it to see where each goes after the manipulation.
Message 3 of 17
(6,289 Views)
Strings.  Numbers.  Who cares?  The array manipulation is the same.  Just change the representation inside of the array to whatever data format you need.
Message 4 of 17
(6,285 Views)
I know, however I thought that "for the intersting part", u meant it was because it was letters :). I was wrong.
I tried your method, but in the small for loop, I can't get the same icon than you for the array.
Here is my attached VI.
Thank you,
Zepiii
Message 5 of 17
(6,282 Views)
I used Index Array where you used Array Subset.  And then use the autoindexing on the output tunnel of the inner loop.
Message 6 of 17
(6,277 Views)
Thank you.
People on this forum are just amazing !
It works!
Cheers!
Message 7 of 17
(6,275 Views)
It amazes me that you got a reasonable answer, because your question is not clear at all. 😄
  • Why the arbitrary restriction that it has to be done in a for loop?
  • "would like to extract this" is unclear. What is "this"? Extract cells C4-E4? Extract columns C-E? Extract Row 4?
  • What do you mean by extract? Keeping only the extracted part or keep everything except the extracted part (or both)?
  • Is this a table or a 2D array?
Message 8 of 17
(6,264 Views)
Well, english isn't my mother tongue, sorry about that... Crossrulz perfectly understood my question, so just open the VI I attached and you will have the answer to all your questions 🙂
About the for loop, I wasn't sure about it, but it was not necessary. But at the moment, I'm working in a for loop, and this is a small part of it, so I prefer to ask to do it a for loop, in case of...
Message 9 of 17
(6,258 Views)
Ha.  I didn't event notice that line in the original post.
At least the OP gave a before and after of what they wanted.  That's the only reason I had a clue about what to do.
Message 10 of 17
(6,257 Views)
