Manipulating 2D arrays
Hello, need some help to make a VI that will modify a 2D array based on information in one column.
For example belowshows original 2D array:
Command  # # Address Data0 Data1
RD_LONG       0 1 4945 80 -
WR_LONG 3 1 4945 80 -
RD_LONG 3 0 3246 0 -
WR_LONG 3 0 3246 80 -
WR_LONG 3 0 3248 3C -
RD_LONG 3 0 3250 5
5
The modification consists in detecting if  column5 contains valid data. On the above example we see a number 5 on data1 which is a valid digit,  once this is detected a new 2D array must be converted as follow:
RD_LONG 3 0 3250 5
RD_LONG 3 0 3251 5
Once valid data was detected, a copy of the row where the condition was met will need to be copied and inserted below,  only incrementing the address number by 1 and passing column 5 Data1 to Data 0 (col4) of in new inserted row.
Any pointers will be greatly appreciated...Thanks!
(2,532 Views)
It is expected that you attempt the problem and post a VI of your work.
(2,512 Views)
