Manipulati​ng array
@jamesy777 wrote:
They aren't initialized becuase i didnt know they had to be. I'm guessing I wire up indicators with defaults set to 0 ?
I also have a typo ( Uint32 references should be called Uint16)
If they are not initiaized, they remember the last value from the previous run (in the same edit session). Just right-click the left SR and "create constant".
Here's a very stripped down version just showing how the conditional tunnel works. (Note that "index array" is resizable).
Message 11 of 15
(1,211 Views)
Thats definitely a neater solution, Now that the UINT8 data is in a seperate Special array i need to look at each row and start to assemble the TEMP_A/TEMP_B names and associated shared variable links.
Are shift registers the way to go here? Looking at the huge input excel it looks like all UINT registers are written like:
4
8000 0004
5
8000 0005
So maybe i could use the "Special" array as an input to some kind of autoindexing for loop which will pick out every 2 rows in the special array and assemble the uint16 message names and locations.
Any ideas?
James
Message 12 of 15
(1,203 Views)
Heres my attempt attached, my problem is how to append an additional row to an array using an auto-indexed for loop.
This VI gives me :
A
B
CB
D
E
FE
I want
A
B
AB
C
D
CD
I'm sure there is a simple solution.
James
Message 13 of 15
(1,163 Views)
Accepted by topic author jamesy777
Try this:
Message 14 of 15
(1,149 Views)
Thanks, the concat option on the outout tunnel was really useful. Its working great now.
James
Message 15 of 15
(1,102 Views)
