Mandatory terminal input
When creating sub vis can I create an input that if not
wired would create an error ?
(2,935 Views)
Accepted by topic author Ben_01880
Yes!
When you wire the connector pane select the terminal right-click and chose "this connection is-  required"
"Should be" isn't "Is" -Jay
(2,934 Views)
Thank you
(2,922 Views)
Also, note that there is an options setting on the Front Panel Tab to make "Connector pane terminals default to Required".
Omar
(2,909 Views)
