Manchester Encoding with PXIe-6345
Hello All.
I have a product that has only one data input and is expecting a Manchester coded data stream with a bit frequency of 300Hz with about 100ms between frames.
Can I use 2 PFI (One for data and one for clock) channels of the 6345 in a XOR gate to create this stream?. I guess I need a few start bits and end bits to synchronize the message to the product?
Any help if much appreciated.
Thanks in advance
(2,347 Views)
Hi Monster,
So you want to output a DO signal containing a Manchester-encoded waveform?
You could create that waveform using the XOR function and two boolean arrays (data and clock)…
Why do you need PFI pins for that task?
(2,337 Views)
HI,
Yes we would use Digital output / PFI.
I was thinking using PFI would be wiser to use to generate a accurate 300Hz clock for the encoding process. We have those available anyway in the 6345 not currently used.
We do have some start and stop bits in the sequence. So I guess we can use those to sync the message on the product side.
Regards
Peter
(2,327 Views)
Hi Peter,
Your 6345 supports output of digital waveforms on port 0.
So you can create digital waveforms and "play" them at the desired samplerate over one of the port0 pins.
That waveform will be as accurate (in terms of "accurate 300 Hz clock") as any generic clock signal of the counter engine…
Instead of "guessing" you should read the datasheet of that product to know which signal to send…
(2,289 Views)
