Making an Output Required
I want to make a sub VI output Required. This is apparently not an option. Am I missing something here?
(VI attached. Notice that this can't work as a sub VI without wiring the output terminal because LabVIEW will crash.)
Message 1 of 8
(5,095 Views)
If LabVIEW crashes, we a more serious problem. Can you tell us your LabVIEW version and exact steps on how to recreate the crash?
What is your setting for automatic error handling?
Message 2 of 8
(5,093 Views)
Erm, sorry, "LabVIEW crashes" is really not what I meant. (I was in a hurry... ironic in that it's making this take longer, eh?)
I get the "Error XXXX occurred at blah blah blah... Continue/Stop?" pop-up. Yeah, that's automatic error handling (not a "crash"), but I like automatic error handling. I don't want to turn it off. Thus, I need to make sure those terminals are always wired.
Should I try to dig up that "make a feature suggestion" page, or has this issue been covered already?
Message 3 of 8
(5,087 Views)
A couple of people have managed to create a VI with required outputs. The 'secret' han not yet been revealed, but you can monitor the discussion on the LAVA forums... I would like to know how too...
(Even some NI folks would like to know how this was done, so it certainly sounds like a "suggestion page" candidate Smiley Happy
Message 4 of 8
(5,079 Views)
I still don't see why the VI would crash if the output is not connected. Which VI are you talking about that needs a required output?
Message Edited by S G on 12-11-2007 01:20 PM
S G
Certified LabVIEW Architect, Certified TestStand Architect, Certified Professional Instructor
Message 5 of 8
(5,062 Views)
Read further, he's not crashing, just bothered by the automatic error handling if the error output is not wired and an error occurs. 😉
Message 6 of 8
(5,050 Views)
yea, i am still waiting on them to give it away. my patience is stretched Smiley Very Happy i would love to have this feature.
... And here's where I keep assorted lengths of wires...
Message 7 of 8
(5,032 Views)
Anyone know if there was any further development on this? The thread on the LAVA forums seemed to take a detour. I was playing around with this a while back using LabVIEW 7.1.1 and scripting, but got side-tracked by real work, and I never went back to it. This morning I decided to try doing it with a hex editor and was successful, though there's the odd side-effect that the Info window shows the correct display in terms of its wiring property, but when you right-click on the indicator it doesn't. And, yes, placing the subVI in a new VI causes the parent to indicate that you must wire to the output, as expected. That part is just "neat".
Message 8 of 8
(4,921 Views)
