Making a plot visible without property node?
Consider using a CONDITIONAL DISABLE symbol to control that.
If you create a new CONDITIONAL DISABLE SYMBOL called "MakeAllPlotsVisible" and enclose the initialization code in a CONDITIONAL DISABLE structure with a condition of MakeAllPlotsVisible == TRUE, then you can turn it on when you gorch the plots again, but it doesn't take up code space when not necessary.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 11 of 11
(497 Views)
