Making a New File Using "Save As"
Little feedback to the NI Staff here...
We are using LabVIEW 8.6; and, at least in this implementation, trying to make a new VI by using the Save As command produces a menu of choices, none of which make sense to me. Sorry, but I can't tell which of them will actually just produce a new file with an amended name to be further developed. Trial and error produces the creation of folders, but no files, overwrites the original file (why would I want to do that, I selected Save As not Save) and just about every result other than what I was trying to accomplish.
Maybe you have fixed this in a later version, but for 8.6, I feel like I need to take a class just to save the new file.
(2,828 Views)
Accepted by topic author DoctorT
you're not the only one...  😉
Have you tried "Open Additional Copy"?  It is probably what you want.  It will not copy over the original one, and will keep the original one open.
(2,826 Views)
OK, mods can delete this if you want. The default which says
"Substitute Copy for Original"
contrary to what I interpret that to mean, actually produces the desired result. Confusing, but can make it work. EOR
(2,821 Views)
Substitute copy for original will not delete the original, but may swap the VI if it a subvi inside an opened VI.  (I have not checked if it does the same when the VI is closed).
I know it is confusing.  Don't delete the thread as it may be useful for others.
(2,814 Views)
