Make programmatic calls to a Dll using Labview
Hello All,
I know that in order to interface with a DLL I have to use "Call Library Function" interface. Sometimes the process of identifying function parameters type and building a vi for each dll function is time consuming and error prone. Is there any vi out there that actually bypasses the above process and make direct calls to a Dll?
Thank you for your help.
(2,614 Views)
Nick_1;
As far as I know, that's not possible. You need to do the work.
The only time I know the "Call Library Function" populate itself is when the dll was made with LabVIEW.
Regards;
Enrique
www.vartortech.com
(2,594 Views)
