Make own create VI resusable
I am sorry but I still don't get it how you did it.
I can see you have taken out the I/Os and made them as connectors.
My whole idea is to have a subVI with wirable connectors which will be called signals, but also internal parameters that can be only modified if the subVI is opened ( these will be like initial parameters of my function). Now, I would like to  use that subVI serveral times inside a main VI, which means, each instance of the same subVI will be called at the same time and hence I will have access to as many front panels of the subVI as their number.
Message 11 of 12
(419 Views)
Hi idir,
as I wrote before: I took YOUR VIs and only changed the subVI's visibility. Then you can access the front panel controls of each instance...
Message 12 of 12
(410 Views)
