Make executable file from VI file
Hello!
I would like to know how to generate the executable file (For example: instruments.exe) form original vi Labview file format. Is it possible to run the VI without Labview or Labview Viewer on any 32 bit Windows system? (95/98/NT/2000).
Thank you for your help.
Yours sincerely
Vik
(3,137 Views)
What you need is the "Application Builder" (see http://sine.ni.com/apps/we/nioc.vp?cid=10730〈=US for more info)
From the ni.com website:
"LabVIEW Application Builder [gives you]
* Ability to create stand-alone executables
* Protected applications
* Easy-to-use Distribution Kit Builder
* Included as part of the LabVIEW Professional Development System
The LabVIEW Application Builder is an add-on package for creating stand-alone applications. When used with the Application Builder, a LabVIEW system can create VIs that operate as stand-alone applications. You can run the executable, but cannot edit it."
So, if you have the LabVEIW Professional Development System, then it's alreay built in (you can find it under "Tools">"Build Applciation or Shared
Library (DLL)". If you don't have the professional development system, then the App. Builder can be purchased separately.
Once the exe has been built with the App. Builder, the target machine needs to have the Run-Time Engine installed as well...
cheers,
Christopher
Christopher G. Relf
Certified LabVIEW Developer
Christopher.Relf@mBox.com.au
Int'l Voicemail & Fax: +61 2 8080 8132
Aust Voicemail & Fax: (02) 8080 8132
EULA
1) This is a private email, and although the views expressed within it may not be purely my own, unless specifically referenced I do not suggest they are necessarily associated with anyone else including, but not limited to, my employer(s).
2) This email has NOT been scanned for virii - attached file(s), if any, are provided as is. By copying, detaching and/or opening attached files, you agree to indemnify the sender of such responsibility.
3) Because e-mail can be altered electronically, the integrity of this communication cannot be guarant
eed.
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(3,136 Views)
