Make SceneWIndow always visible (3D Picture Control)
I am using 3D Picture Control to render a STL assembly and then show it in a SceneWindow.
The problem is that I cant make this seperate Window be always on top.
This is what I get from property window:SceneWIndow.png
How to obtain the FrontPanel reference?
(2,396 Views)
Hey Vinicius,
Let me get that clear. In summary what you need is to have a front panel window to be always on top. Am I right?
If so, I recommend you to use the VI property "Is Frontmost". Instead of looking for the FrontPanel reference, try using a VI Reference to find the adequate property to make the Front Panel always on top.
Hope it helps.
Best,
Felipe Flores
Technical Support Engineer
(2,333 Views)
