‎11-19-2012 10:56 PM
I've Main VI which includes event structure. When START button is pressed, I start data capturing which is in WHILE loop. I want to ABORT the data capturing. The ABORT button is on Main VI. But Main VI is unresponsive when sub VI while loop is executing. How to ABORT the data acquisition? I can not change the structure.
Solved! Go to Solution.
‎11-19-2012 11:02 PM
Can you post your code? Sounds like your subVI with the while loop is in your event structure for one. Secondly, you need a method to tell the subVI that the Abort button was pushed.
‎11-20-2012 10:53 PM
Thanks for reply. I sorted out the issue. I had made mistake. I have event structure and the event case is common for 4 control's Value Change event. I had unchecked Lock Front Panel for one of the control's event and for others it was lock front panel. Thats why it was unresponsive.
