Main front painel
hi,
How can i execute a front painel before the main front painel for languague selection of my program?
When user select a button it have to close that painel and open the main.
I try this...
but I can't make the Main VI run in the same time this close. Any suggestion to solve this problem?
Thanks for help 😄
(3,412 Views)
Depends...how do you change the language?
(Or ,how do want to tell the main application wich language to choose? )
Greetings from Germany
Henrik
LV since v3.1
(3,406 Views)
I'm doing the languague selection with diferents vi's, one in portuguese other in english (I push the button english and it open the english vi and the same for portuguese).
Grettings from Portugal,
João
(3,391 Views)
I João,
first of all I will try to explain what I want.
Forgetting what I sent:
1. º needed to know how to put the values of a sensor that appear on a chart in excel. This order should be given by a button. Could later refer to this file in excel.
Can you help me?
2. º needed to know how to acquire image webcam integrated into the laptop and the sound of the laptop, when I press a button on labview.
When I click on another button the picture and sound is turned off.
3. º I make a remoting application developed in labview from another PC elsewhere.
I used the Web Publishing Tool. The problem, I realized what it was I did not have a fixed IP. Can I do that?
Best regards and thanked lot for your help!
PS: Podemos falar em português se assim o entenderes 🙂
(3,384 Views)
Ola!
Sobre a 2º e 3º questão não te posso ajudar, ainda não desenvolvi nada que necessita-se dessas opções.
Quanto ao excel ve na imagem em anexo se o que fiz se adequa ao que pretendes. Não te esqueças de mudar a localização da directoria onde pretendes guardar o ficheiro.
Abraço
(3,380 Views)
Viva João,
Não conheces ninguém que me possa ajudar nas questoes 2 e 3?
Precisava mesmo!
Em relação ao que me enviaste eu penso que sim, pois o meu objectivo é o seguinte:
Obter os dados dos sensores e transferir os valores para excel para depois serem consultados.
Envio-te em anexo o meu trabalho para veres onde poderei inserir esse código. Entra no separador Body Temperature Sensor.
Obrigado pela ajuda!
Abraço,
(3,373 Views)
