MSB first or LSB first
How can I write an easy program (on Labview) that the word i send , on SPI, is on configuration LSB first or MSB first depending the user's choice.
Kind Regards
(8,153 Views)
Accepted by topic author Julie26000
You would use the Swap Bytes function.
Use a Boolean control to allow for selection between LSB and MSB. LabVIEW is big endian (MSB LSB) internally. To send the word as LSB MSB, use the Swap Bytes function before passing the data over SPI. This could be done by passing the word through a case structure.
(8,134 Views)
Thanks!!!!
it's really easy, I have searched more difficult than that!
kinds regards
(8,124 Views)
