MS Word AutoFit behavior
I'm attempting to edit the AutoFit behavior of a MS Word 2003 report generated through the Report Generation Tool, but I'm having some trouble with ActiveX. I referenced an earlier thread I found via search here, but it's from 2006 so I'm not sure if either it's still applicable or if I am doing it wrong.
I've attached my VI with a comment where I'm getting an error. I think it has to do with referencing the index, but as far as I know, "1" references the current table/graph... If someone could point me in the right direction or help me with the solution, I'd greatly appreciate it.
(4,755 Views)
Hi ChaoyD,
One way you can troubleshoot this is to create the macro in Microsoft Word of what you are wanting to do and then take a look at the macro code that is generated. From this you can follow it step-by-step to see which ActiveX calls are called and you can basically follow these calls in LabVIEW to make sure you are using the correct references for what you are trying to accomplish.
Tommy G.
Product Manager - Search, My Account, and Chat
(4,737 Views)
Thanks, Tommy. I'll try that.
(4,733 Views)
Can you save you vi in LV2009?
Ben64
(4,732 Views)
Had to make a .zip because of a subVI I used, but here's the LV2009 of it.
(4,726 Views)
Accepted by topic author ChaoyD
Hmmm ... this subVI looks familiar!
Try this (I haven't tried it in your vi but I know it works as a standalone).
Ben64
(4,724 Views)
Fantastic. I feel like such an idiot for being so close, yet so far. At least in the future I'll know the tip for recording a macro then looking at it. Thanks again, both of y'all. Especially ben64, who's been so helpful with all my RGT questions so far Cat Happy
(4,718 Views)
