MS SharePoint Online
I'm looking for some help with authenticating from LabVIEW to Microsoft SharePoint using a client_id and client_secret
I have a snippet of Python code that seems to do the trick, but I am looking to do this all in LabVIEW as my solution needs to be compatible back to LV2011. Initially I tired using the RESTful API but hit a dead end as it would only give me a username and password (I'm not an expert in Python).
Here is the python:
from office365.sharepoint.client_context import ClientContext
from office365.runtime.auth.client_credential import ClientCredential
site_url = '<myURL>'
app_principal = {
'client_id': '<myClientId>',
'client_secret': '<myClientSecret>',
credentials = ClientCredential(app_principal['client_id'], app_principal['client_secret'])
ctx = ClientContext(site_url).with_credentials(credentials)
web = ctx.web
ctx.load(web)
ctx.execute_query()
print("Web site title: {0}".format(web.properties['Title']))
Again through google search I came across a MS article doing something similar with the SharePoint Client dll. However I get stuck at the context.load(web) function as it does not appear to be part of the property node.
Complete basic operations using SharePoint client library code | Microsoft Docs
Any help would be greatly appreciated, or advice with how to do this a better way through LabVIEW. Ideally I would want to use the RESTful API as this is well documented across the web with doing various tasks on Sharepoint.
Kev
(1,853 Views)
Here is the python:
app_principal = {
web = ctx.web
ctx.load(web)
ctx.execute_query()
If you have python that works, try using a LabVIEW python node. see this (or google it):
https://blog.sasworkshops.com/python-node-basics/
Once you open a handle in python you may need to keep calling the python session to interact with it.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
(1,848 Views)
Thanks for your reply. I wish it was as simple as that. My code needs to be backward compatible with LV2011 which the python node is only support as far back as LV2018, unless I am misinformed (Integrating Python Code in LabVIEW).
Many thanks
Kev
(1,786 Views)
