MS Office Parameters change in Program
I want to configure MS Office Parameters automatically in the program instead of directly with LabView.
Do someone have an example on how to do that?
I tried also to define a cluster as input, But it didn't work !
(3,017 Views)
What does this mean?  What do you want to do with the MSOP?  You need to set them to something -- what do propose to use?  What does "automatically" mean?  And if you don't set them directly with LabVIEW, how do you set them?
If we don't know what you want to do, we can't create an example!
What cluster?  Where is it?  What do you mean by "define a cluster as input"?  What do you mean by "it didn't work"?
It would be so much easier to help you if you did a little work yourself and copied the code you want us to inspect and correct into its own VI and attach the VI instead of a picture.  With a VI, for example, we would see Errors (if they exist) and could read the Error Messages ...
(2,957 Views)
