Showing results forĀ
Search instead forĀ
Did you mean:Ā
MS Access ActiveX
How can I read column headers from an MS Access file using ActiveX?
I'm already reading content from file, now I really need to read the headers.
Message 1 of 11
(5,516 Views)
I have something that uses LabSQL as a baseline with additonal functions to get the column names from a ADODB._Recordset activex class.
What version of Labview are you using?
David
Message 2 of 11
(5,503 Views)
I'm using LabVIEW8.0.
Message 3 of 11
(5,500 Views)
OK try these and see if this helps you.
David
Message 4 of 11
(5,497 Views)
David,
Thanks for your help, but your code is returning me an error (code: -2146824579), and I couldn't found the reason.
I'm using the Acces._Application ActiveX class to read the containing data for a *.mdb file, like at attached VI. Is there, in this class, any way to read column headers?
Message 5 of 11
(5,484 Views)
Ah you are using DAO and I am using LabSQL from http://jeffreytravis.com/lost/labsql.html. LabSQL uses ADO instead of DAO.
Sorry I don't have any DAO vi's apart from those in the ZIP attached which I picked up from NI website, I think.
I haven't tested them before this post but I think this will do what you want.
David
Message 6 of 11
(5,481 Views)
David,
Thank you very much! The last post was exactly what I need!
Regards!
Message 7 of 11
(5,477 Views)
It DAO is very old for LabView 8.6.1 Smiley Sad
www.elblogroboticodepedro.tk
Message 8 of 11
(4,693 Views)
Sorry, but the lowest version I have here is 8.5.1.
Perhaps someone else on the forum can help up-convert these VI's for you.
David
Message 9 of 11
(4,679 Views)
Saved in LV8.2
Message 10 of 11
(4,672 Views)
