MRI Simulation - need guidance
Since the images the RGB components are the same, so one is enough. Place the attched VI (LV 8.6) in the same folder as your images, and it will give you some ideas how you could do things. Modify as needed.
Message Edited by altenbach on 04-17-2009 11:34 AM
Message 21 of 25
(1,630 Views)
Here's the LabVIEW 8.0 version.
Message Edited by altenbach on 04-17-2009 11:39 AM
Message 22 of 25
(1,626 Views)
Wow thanks altenbach
Thats a lot more elegant than what I had. Do you mind if I use your code?
Message 23 of 25
(1,617 Views)
Sure! 🙂
Of course it's only a very quick draft. so you probably need a few more tweaks.
Message 24 of 25
(1,604 Views)
Aren't these forums and members awesome! You can literally and figuratively look inside someone's brain and have a solution in a short time 🙂
-AK2DM
Message 25 of 25
(1,589 Views)
