09-18-2025 09:37 AM
Hello again,
Been working on a little MQTT setup. The setup isn't too complex but I can't seem to get the data to come in or get parsed correctly. Not sure what the issue is since I've been tweaking it for a while now but I do notice however that the issue seems to be with how I'm handling the incoming payload from the MQTT client. I'll also point out that I am using an Ammonia sensor connected to an ESP32 - the measurements are already being taken and the MQTT publisher, broker, subscriber are working together fine so my PC receives the data just fine but I can't get it to work in LabVIEW.
The gist of the code is to subscribe to the publishing data via MQTT (step complete), take the incoming JSON data and have the real-time changing measurements display individually in the front panel (type - string, concentration - numeric, temperature - numeric, voltage - numeric). I also included a waveform chart after an Unbundle node to display only one of these variables at a time for now but can't display any of the measurements yet.
I'm including a few versions of my current setup and also a screen shot of how the string data looks when its received on a Serial Monitor outside of LabVIEW. Please let me know what I'm doing wrong here. Thank you in advance!
Kind regards,
PDB
Solved! Go to Solution.
09-18-2025 09:54 AM
Use Decode Application Message (Raw).vi instead of Decode Application Message (Type).vi.
The one you are using now is expecting flattened variants on the wire iirc. You can use that when communication between LabVIEW programs.
Use byte array to string to convert the payload to string and then unflatten from JSON.
09-18-2025 10:14 AM
I can't open your VI's (still on 2023) but I can say if you're using the built-in JSON library, I recommend switching to the JSONText library: https://www.vipm.io/package/jdp_science_jsontext/
It's VERY flexible and has a LOT more features than the other libraries I've tried.
09-18-2025 10:23 AM
An example of two ways to decode the message using JSONText, assuming you get the whole JSON bundle from your MQTT library:
The "$" notation is a little confusing at first, but you get the hang of it. "$" just means the "root" item in the JSON input. Dots let you get sub-items.
09-19-2025 03:16 AM - edited 09-19-2025 03:16 AM
Good point, the cluster should contain scalars, not arrays.
See also this github issue where the creator goes into a lot more detail and shows how you can deserialize JSON data directly using a custom serializer:
https://github.com/LabVIEW-Open-Source/LV-MQTT-Broker/issues/169#issuecomment-950385388
09-22-2025 02:24 AM
Hey again,
Thank you so much BertMcMahan and cordm! This solved the issue completely and the resources are great too.
Kind regards,
Paul
