MPPT - array build
I'm a student in Power engineering and I'm trying to build a MPPT simulation.
My question is, how can I make from two different arrays one common. EXP:  1D {1,1,1}  2D {0,0,0,0,0,0}  --> 3D {1,1,1,0,0,0,0,0,0}
My purpose is to get a Duty Cycle (digital) and connect it to the boost convertor
3D array is the final pulse where T(on) is 1,1,1 and T(off) is 0,0,0,0,0,0
Those array's parts have to be out put in 5us each one
(2,615 Views)
Hi student,
you want to concatenate two 1D arrays into one, there is no 2D or 3D array in your example.
Use a BuildArray node and set it (by right-click menu) to concatenate mode!
(2,611 Views)
