MP3 file using FM modulation
Hy, I want to send a MP3 file using USRP and FM modulation, I have created a VI but I have a problem, it gives me this error: niUSRP Write Tx Data (CDB Cluster).vi<ERR>Underflow: the Tx buffer was emptied before new data was provided.  Consider reducing the IQ rate, increasing the Write rate, or increasing the number of samples per Write
I made my VI using an existing VI, Playback FM.
Can anybody help me?
(3,160 Views)
Check this out:
http://digital.ni.com/public.nsf/allkb/AB7D4CA85967804586257380006F0E62
This describes a similar Error with NI-DAQmx and what you can do to resolve it..
Did you follow the suggestions that you describe in your post?
What was the result?
regards,
adigator
(3,098 Views)
I followed the suggestions in my post and it still doesn't work.
I really have no idea what to do.
(3,075 Views)
