MIDI Read function in LabVIEW 8.2
Is there a MIDI read function in LabVIEW 8.2?
(4,824 Views)
http://forums.ni.com/ni/board/message?board.id=170&message.id=280480#M280480
You could have aksed it in your previous post since it concerns the same functions.
André
Message Edited by andre.buurman@carya on 10-26-2007 09:12 AM
André (CLA, CLED)
(4,811 Views)
The following Developer Zone article contains a program that uses LabVIEW to select a MIDI device, channel, patch, volume, and pitch, and to play the note for one second, as well as other features.
Communicating with a Windows MIDI Device in LabVIEW
Hope this helps!
Amanda Howard
Americas Services and Support Recruiting Manager
(4,786 Views)
Sorry about the multiple posts, I appologize.
I don't think I was specific enough in my last post either.  I am using the MIDI-OX/MIDI Yoke/MIDI Bar to read MIDI files.  I was wondering if there was a function in LabVIEW that can read the information from the MIDI-OX/MIDI Yoke/ MIDI Bar, so that I can write programs on an external DSP device, where I will be applying filters, synths, etc to the MIDI file then outputting it from the DSP device.  I have an info PDF file that says there is a MIDI read function that is found as a custom numeric VI.  I have LabVIEW 8.2, and the file concerns LabVIEW 8.5.  Is there a way I can configure my program in 8.2 to do this, or must I upgrade to 8.5, or is this even possible?
(4,778 Views)
If you attach the VI, I can convert it to 8.2 for you. Otherwise, you'll need to open it in 8.5.
Thanks!
Amanda Howard
(4,746 Views)
