MIDI IN
Stefan,
Yes I did, on Tuesday morning. And I responded by sending you a Zipped archive of my LabVIEW library.
Since you are writing this I guess you didn't receive it. I'll try sending it again, but the original message never came back.
Larry
Message 11 of 23
(4,247 Views)
Hi Larry Goga
I am too working on a LV program that requires obtaining MIDI input data from a keyboard, modify it and pass it through to the Windows MIDI output. I tried to build a MIDI_IN.VI using the WIN32 API but still do not have any luck yet. I have to admin that I am a hardware guy and not experience in complex software such as the callbacks etc. Can I also have your beta test working solution to try out?
Thank you
pchew
Message 12 of 23
(4,198 Views)
Hi Larry,
Thank you for the solution. It work!!
pchew
Message 13 of 23
(4,168 Views)
Larry,
How is the beta testing coming along? Do you still need womeone to help out?
Message 14 of 23
(4,093 Views)
This solution was submitted to the NI Developer's Zone several months ago and I am still waiting to hear back from them. I am told that their wheels grind exceedingly slow, but exceedingly fine. If you are desperate for a solution please write again and I will forward to you what I have.
Larry
Message 15 of 23
(4,088 Views)
Thanks for the offer. Please forward
I am in the process of improving a Labview program to include control from a MIDI device and would like to complete that update in the next few days.
(got two gigs this weekend)
The info at MSDN is not easily followed when I don't have a MS compiler.
Message 16 of 23
(4,084 Views)
it's been a while when the last post was written, but I've the exact same problem, that I need some method to work with the input of MIDI Signals.
Are there any updates to that mentioned beta?
Could I have a copy of it, as well?
Tim
By the way: has anybody an idea, what interface board I'd need to get some MIDI data coming from trigger-clips from drums
Message Edited by useratni on 04-16-2009 02:50 PM
Message 17 of 23
(3,573 Views)
A solution to the problem of inputting MIDI data into a LabVIEW program can be found at the following URL:
http://zone.ni.com/devzone/cda/tut/p/id/6223
Good luck,
Larry
Message 18 of 23
(3,563 Views)
There are some broken links in the NI's article. Since thge last post was in 2009, now we have WIndows VISTA/7. Will this work on 7.0?
Message 19 of 23
(2,891 Views)
Hello wprice,
Although the last post to this thread was in 2009, the actual work to develop this solution was done back in 2006 - over 5 years ago.  Since then, there has been no new development work on this project nor is there ever expected to be any.  I'm afraid that this solution is, and will remain, exactly what it is... a solution for that problem at that point in time with that software.
I'm sorry that I cannot be of more help.  Good luck with your further explorations.
Larry Goga
Message 20 of 23
(2,885 Views)
