MAX error add/remove software
This happens when i try to install software with MAX version 4.7.7 f0. I did a compleate uninstall and reinstall of whole NI developer suite 2011 and still i have this problem
MAX error
(4,106 Views)
Can you please tell me more about your system? What controller you have there?
Kind regards,
Ion R.
(4,070 Views)
I am running Win7 64bit and I am using PXI-8109 controller. But i belive that controller is not problematic because i can install software forom other PCs.
(4,065 Views)
If you ping the controller from this Computer? Do you have the right IP specified in MAX?
If you try to reinstall software on another PXI, I see that you have two of them, does it responds correctly?
Did you try to rename it in MAX?
(4,063 Views)
I can see IP and i can ping PXI. I have the same problem with the other crate.. actually with any crate.
(4,061 Views)
Please try also to install MAX 5.0 , maybe you have a corrupted file and it will solve this problem.
(4,055 Views)
I saw on your first post that you did a completely uninstalling and reinstall NI Developer Suite 2011.  I would kindly ask you to update for example DAQmx driver. Daqmx 9.4 will also update your MAX to 5.0. Please try it and let me know if that solved your issue. You can download this driver from www.ni.com/drivers
(4,039 Views)
