MAX custom scales give different values in LabVIEW
I'm having a MAX issue I think.  I have several tasks configured to run on a CDAQ chassis.  Each channel in each task has custom scales defined in MAX.  When I run each task in MAX, I get properly scaled values.  When I run the same tasks inside a VI, I get junk.  As in, the values either aren't scaled or are scaled to something arbitrary.  Anyone seen this before?  Anything I should check into?
Thanks.
CLAD
(2,546 Views)
Hey,
Do you see this behavior if you use a pre-built shipping example, or just in your custom application?
Matt W.
(2,487 Views)
