MAX cannot save configuration file
on a fresh installed Windows 10 with TS2017, LV2018, ICP18.0 i wanted to add a new DriverSession in MAX.
But when i press then i get the attached error (Unable to save configuration to the location).
What can i do to make this work?
(3,888 Views)
Accepted by topic author OnlyOne
Hi OnlyOne,
Can you try to run NI MAX as Administrator?
As stated in ICP 18.0 readme: http://www.ni.com/pdf/manuals/376942b.html
In ICP 18.0 and IVI Shared Components 2.6, the installers no longer unlock the IVI Foundation directory. Therefore, you no longer can modify the files installed under the IVI Foundation directory. Furthermore, if you want to make IVI configuration changes in MAX, you must launch MAX with Administrator privileges.
Hope this helps.
Patrik
CTA, CLA
Helping (sharing) is caring!
If the post was helpful - Kudo it.
If the post answered your question - Mark it as Solution.
(3,849 Views)
Yes, it is working when running in Admin mode.
(3,845 Views)
