MAX and VISA Resources
I have MAX version 4.6.1 installed from NI-VISA 4.6.2.  Recently I upgraded from LabView version 8.5 to 8.6 after which I have lost all previously used VISA resources.  When I launch MAX it indicates there aren't any VISA resources found.  I have tried adding VISA resource and I am able to validate the connection and verify connectivity using the VISA test panel.  However, after I refresh VISA resources in MAX it loses the newly added (and saved) VISA resource.  MAX returns the following error code:
0xBFFF0011 (VI_ERROR_RSRC_NFOUND)
Additionally, I have tried the following without success:
Removing MAX and reinstalling using NI-VISA without success.
Importing a colleagues configuration data.
Has anyone experienced this issue and know how to fix it?
(2,623 Views)
Hello, did you reinstall drivers after upgrading LabVIEW? You will need to run the VISA installer again. As well as any other drivers you want to use in LabVIEW
(2,579 Views)
