MATHSCRIPT array to IMAQ
I have a 2D array coming out of Mathscript; values of 0 and 1, the 1's form a small rectangle in the center.
So I  expect to see a small white rectangle in the center.  but all I see is black.
I have attached the simple VI in both ver 8.5 and 8.0.
Thank you.
(3,245 Views)
The pixel type you choose is U8. 0 is black, 255 is white. So you should change "1" to "255". Then you will see a white rectangle in the center.
(3,234 Views)
Thank you. I changed the 1 to  255 and it worked.
Have a pleasant weekend
(3,227 Views)
